81 K10 fuse panel layout
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
Hey all.. I’ve read lots of posts and realize I need the fuse panel layout specific to my 81 K10. I’ve used similar layouts from close years but it seems there’s something unique about the 81’s. Does anyone have a fuse panel layout for an 81 k10 manual trans?
My symptoms are intermittent crank no start then poof! She starts like she was ready all along. The other issue is a continuous battery drain in the off position. I have to keep a battery charger on her if she sits idle for more than 36 hours.
Thanks for any help offered!
Strick
Dunn, NC
Harold
C20 Crew
I would look somewhere besides the fuse gang for your issue. If you have intermittent starting issues I'd address the ignition starter switch (column mounted) first. This may alleviate your starting & parasitic draw issues in one repair.
There are a few methods to check for the parasitic draw & someone besides me will post 32 pages of procedure for you to follow.
You can "easily" unbolt the ignition starter switch & use a small screwdriver to actuator the starter where the actuator rod attaches. Try this first & see if you have any hesitation our paused starts.
Strick
Dunn, NC
Harold
C20 Crew
Next you could look for neutral safety switch issues...
Crank no starts aren't caused by fuse box,neutral safety switch,and very very rarely by ignition switch. When you say crank no start, you do mean the starter motor cranks the engine over ,whir,whir,whir,whir but the engine doesn't start correct.
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
Thanks everyone for the replies. Let me describe better what goes on. First of all I have officially named her "Miss Priss" cuz she just starts whenever she wants to. Being she is manual Transmission, If I was to stall her out then try to start her back up, I may have to wait a bit for her to decide when she is gonna start. I will say that I've stuck my foot up under the dash and wiggled on the wires and sometimes that is enough to get her to start but not always. Sometimes the first start of the day makes me wait and "wiggle", sometimes if I go into a store, I always hold my breath when starting to see if she wants to go or not. I do like the direction of the neutral safety switch but I was under the impression that wont even allow the engine to crank at all? She will always crank, sometimes give a couple backfire pops but then its just a dry crank. I wait.. wiggle the wires some, then all of sudden, she comes to life and decides she will allow me to get where I'm going.
issue 2: I have a parasitic draw ( I like that description), I have been leaving a smart charger on her whenever I put her in the garage otherwise in 2 days, that battery is deader than a door nail. (where did that ever come from anyway?) So I keep her on a trickle charge, If I park her out somewhere where she will be sittin for a day or two, I have this solar charger thing that I plug into the cigarette lighter and that seems to always allow her to crank. Wether she starts or not is up to her.
So, correlation between the two? I can't help but think so. Here is another clue maybe? I began pulling fuses with an ohm meter connected to the Red Hot that shows it responds to changes in resistance when the door is opened and the courtesy lights are supposed to come on. (yes, battery disconnected). I started pulling fuses and one fuse removed a measurable resistance completely from the circuit. I have no idea what that fuse goes to because the panel isn't marked. So... that was why I was asking for a panel layout.
The no crank no start is probably something else? But... if that is an ignition fuse? maybe ......?
Parasitic draw take off the negative battery cable,put a test light in between the battery and tge negative cable. Does the test light light? If so unplug the 2 prong connector from the alternator. Is the light still on? Start pulling interior fuses one at a time until the light goes out. Post back.As for your crank no start it's still not a fuse,and it's not a neutral safety switch it is very possibly the electrical part of the ignition switch on its way out,or a wire broken in it's jacket. I'll try to find you the color for the coil primary wire at the switch later. That is the wire it would be with a crank no start.
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
Ricko, I will do exactly as you described and report back. Look forward to any color coding you might be able to provide.
Sorry,forgot to look. Not home right now. Sorry
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
No worries, I did pull fuses and did get a resistance that went to zero on one fuse in the upper left half of the fuse panel but I have no idea what it does cuz the panel isn’t marked anymore. Not dash lights, not radio, not headlights or wipers, not cab lights. Must be something going out under the hood?
Ok I failed to mention there was an LS swap done and there is a new relay set up separate from the new wiring harness under the hood to the ECU. The little fuse block that came with the new harness has 4 fuses in it and two relays. One of the relays isn’t being used because a guy put in another one wired to the pink wire and the hot to the ECU so whenever the key turns on the pump starts pumping which always does even when she won’t start. I can’t help but think that pink wire is good and consistent with the ignition switch to fire up the fuel pump and ECU. Am I thinking right?
Jgonick
West Texas
Joel
Post a pic and we can probably tell you. Choke maybe??
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
Ok here’s the fuse panel. What do these 4 fuses up here do? Im pulling each and seeing what shakes out. So far one out and nothing changes to interior
Jgonick
West Texas
Joel
I think I labeled yours correctly- double check with attached fuse block diagrams
only 81 diagram I could find was a little fuzzy-sorry- looks the same as the cleaner 84 though
Zmann
