81-87 GMC/Chevy
Are you willing to price just the motor as a long block, with no accesories like the manifold and carb and headers and chit?
Ya know its not a factory TBI motor right 89S???
Ok. I get confused what motor will work on what year. I just want to get my Burb fixed. :sad72:
:sad72:
I am trying to think of what all will be differant. I might be getting confused here, between SFI and TBI, hmmmmm, will a TBI intake bolt to pre TBI heads??? I am thinking the bolt holes are angeled differant, but even then, I bet there is an aftermarket TBI intake that will fit the pre TBI heads, then you'd be set. Someone confirm or deny for me so I don't have to look it up. Its been awhile and I am rusty on the newer stuff. Don't give up on it just yet 89S, I might have sniffed something I shouldn't have.
tanz45
Hopewell, PA
I think the Vortec heads have the weird angle.
I will confirm and get back to you 89sub.
Thanks,
I know the vortec heads do. Just not sure on the TBI now. The Vortecs are because of the taller ports and TBI doesn't have the taller ports, so its probably a go with the TBI intake, if not, certainly you can get an aftermarket intake that will accept the TB and the exhaust manifolds are the same. So with that being true, then what else would be differant? And the Goodwrench crate motor can have the dipstick on either side. If fact you have to plug one side or use 2 dipsticks.
Is the vortech style a newer style than the TBI, right?
What about pre-year TBI engines, carbed engines?
So what year motors will bolt into my '89 TBI Burban? Just the TBI motor? And I mean without buying new manifolds and stuff, just strictly bolt in/stock replacement wise, what do I need to look for? I don't wnat to be messing around with different manifolds and ****, or what about teh pulley driven brackets and stuff, where they mount to the block. What year time frame motor should I be looking for? The 87-95?
Ideally 87-95 is what you'd prefer since those will be TBI motors. But pre TBI motor might work too. I know one differance for sure, is the valve covers. Pre TBI bolt on the edge flanges, and TBI bolts thru the center.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I think the heads are different.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Chevrolet 5.7L (8-350).
Small block Chevy cylinder heads came with six or seven exhaust manifold bolts, see illustrations & notes at beginning of part type in Hollander Manual for additional information.
Change induction, exhaust & electrical systems as necessary.
Change oil pans and dipstick locations as necessary.
When using older engines in newer applications, make sure knock sensor can be transferred when used.
When using older engines in newer applications, drill and tap holes for accessories as needed.
Center intake manifold bolts use a different angle than the remaining intake manifold bolts.
Twelve intake manifold bolts used.
|A|, |B| & |C| interchange; difference is intake manifold & fuel delivery systems.
A -----------
VIN "K" (trucks).
VIN "7", option L05 (cars).
T.B.I.
E.G.R. equipped.
Knock sensor used.
Swap oil pans w/oil level indicator sensor as necessary.
A ----------
BLAZER/JIMMY (full size) 87-91 8-350 (5.7L, VIN "K")
BLAZER/JIMMY (full size) 92-93 (8-350, 5.7L, VIN "K")
BLAZER/JIMMY (full size) 94 8-350 (5.7L, VIN "K")
BROUGHAM 90-92 8-350 (5.7L, VIN "7")
CAPRICE 89-93 8-350 (5.7L, VIN "7")
CHEVROLET FORWARD CONTROL 87-88 8-350 (5.7L), EFI (VIN "K")
CHEVROLET FORWARD CONTROL 89-90 8-350 (5.7L, VIN "K")
CHEVROLET FORWARD CONTROL 91-93 8-350 (5.7L, VIN "K"), gasoline
CHEVROLET VAN 87-88 8-350 (5.7L), EFI (VIN "K")
CHEVROLET VAN 89-90 8-350 (5.7L, VIN "K")
CHEVROLET VAN 91-95 8-350 (5.7L, VIN "K"), gasoline
CHEVROLET VAN 96 exc. Express; 8-350 (5.7L), gasoline (VIN "K")
CHEVROLET 10 PICKUP 87 8-350 (5.7L), EFI (VIN "K")
CHEVROLET 1500 PICKUP 88-89 8-350 (5.7L VIN "K", EFI)
CHEVROLET 1500 PICKUP 90 8-350 (5.7L, VIN "K")
CHEVROLET 1500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
CHEVROLET 20 PICKUP 87-88 8-350 (5.7L), EFI (VIN "K")
CHEVROLET 2500 PICKUP 88 8-350 (5.7L, VIN "K", EFI)
CHEVROLET 2500 PICKUP 89-90 8-350 (5.7L, VIN "K")
CHEVROLET 2500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
CHEVROLET 30 PICKUP 87-88 8-350 (5.7L), EFI (VIN "K")
CHEVROLET 3500 PICKUP 88 8-350 (5.7L, VIN "K", EFI)
CHEVROLET 3500 PICKUP 89-90 8-350 (5.7L, VIN "K")
CHEVROLET 3500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
CUSTOM CRUISER 92 8-350 (5.7L, VIN "7")
FLEETWOOD 90-93 8-350 (5.7L, VIN "7")
GMC 1500 PICKUP 87 8-350 (5.7L), EFI (VIN "K")
GMC 1500 PICKUP 88-90 8-350 (5.7L VIN "K", EFI)
GMC 1500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
GMC 2500 PICKUP 87-88 8-350 (5.7L), EFI (VIN "K")
GMC 2500 PICKUP 89-90 8-350 (5.7L, VIN "K")
GMC 2500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
GMC 3500 PICKUP 87-88 8-350 (5.7L), EFI (VIN "K")
GMC 3500 PICKUP 89-90 8-350 (5.7L, VIN "K")
GMC 3500 PICKUP 91-95 8-350 (5.7L, VIN "K"), gasoline
GMC FORWARD CONTROL 87-88 8-350 (5.7L), EFI (VIN "K")
GMC FORWARD CONTROL 89-90 8-350 (5.7L, VIN "K")
GMC FORWARD CONTROL 91-93 8-350 (5.7L, VIN "K"), gasoline
GMC VAN 87-88 8-350 (5.7L), EFI (VIN "K")
GMC VAN 89-90 8-350 (5.7L, VIN "K")
GMC VAN 91-95 8-350 (5.7L, VIN "K"), gasoline
GMC VAN 96 exc. Savana; 8-350 (5.7L), gasoline (VIN "K")
ROADMASTER 92-93 (8-350, 5.7L, VIN "7")
SUBURBAN 10 87 8-350 (5.7L, EFI, VIN "K")
SUBURBAN 10 88 8-350 (5.7L, VIN "K")
SUBURBAN 1500 87 8-350 (5.7L, EFI, VIN "K")
SUBURBAN 1500 88-90 8-350 (5.7L, VIN "K")
SUBURBAN 1500 91 8-350 (5.7L, VIN "K"), gasoline
SUBURBAN 1500 92-94 (8-350, 5.7L, VIN "K")
SUBURBAN 1500 95 8-350 (5.7L, VIN "K")
SUBURBAN 20 87-88 8-350 (5.7L, EFI, VIN "K")
SUBURBAN 2500 87-90 8-350 (5.7L, EFI, VIN "K")
SUBURBAN 2500 91-93 8-350 (5.7L, VIN "K"), gasoline
SUBURBAN 2500 94-95 8-350 (5.7L, VIN "K")
TAHOE 95 8-350 (5.7L, VIN "K")
YUKON 92-93 (8-350, 5.7L, VIN "K")
YUKON 94-95 8-350 (5.7L, VIN "K")
B ----------
CAMARO 87-92 8-350 (5.7L, VIN "8")
FIREBIRD 87-92 8-350 (5.7L, VIN "8")
C ----------
CAPRICE 87-88 8-350 (5.7L, VIN "6")
It would work just fine. All you need to do is slot the two inner bolt holes on each side of the intake, or run a carb manifold with a TBI adapter plate. I would choose the adapter plate method myself. The knock sensor just screws into the block drain plug. Use the oil pan and valve covers that come with the motor. Oh, and also use the correct flywheel for the older 2-piece rear seal engine.
X2 on buckets comment :waytogo:
ESONE
