80's Wiper technology sux
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I'm not sure how the wipers work at all. The only way I could see the motor working off of 0.022V is if there are relays inside the motor housing.
This is with ignition power.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Wiper switch in low.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Wiper switch in high (the only speed that works).
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
If these are the grounds they don't look too bad but I wire wheeled the threads of the fasteners before putting it back together.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
And these are the colors called out in my painless harness.
  • Wipers.pdf
Doppleganger
OH-MI: Just like it sounds
Was that Painless kit one with a GM column or the big $ square body specific replacement?
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Yes, the painless kit
is specific to the 73 to 87 truck.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I bought the 10205 but the 20205 has better pictures and not much changed.
looks to be them military tactical wipers
Anyway, it looks to me like its binding or something is interupting the power and ground circuit because they arent constant they are jerking and slowing down very fast, I would check those wire connections and provide a nice new ground straight to battery and bypass switched power with a junction block wire or cable and see what happens. If it gets better, you have an idea. if it doesnt, it tells me its internal to the assembly or the linkages. if you put the wipers in up position where they stand off the windshield, do they move faster
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Should I be getting 12 volts on the 2nd and 3rd pins?
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
My kit came with the two different style connectors for either steering column. It lets you populate them. I know I wired them correctly. But my column has been suspicious since I got it. I think someone modify the intermediate shaft and managed to get the steering wheel 180° out. The turn signals don't work well, the horn didn't work, and I would not be surprised to find they messed up the wiper switch as well.
squarelyfe
NORCAL USA
Larry
k25
Genuine 70's / 80's wiper technology..
gmbellew
Kansas city
glen
suburban 1500
purple is 12v for high. gray is 12v for low. I'd also check the connections at the base of the steering column where the switch plugs into the harness and see if they match what has voltages under the hood.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I would honestly be fine with a switch on the dash. At least the wiring would be easier to check and repair then digging in the column.
jlyon1006
