Wilfred
- Nov 2, 2020
- Western Massachusetts
- Wil
- Blazer
- 350ci
I came across this torque sequence for installing my ball joints:
Has anyone else ever have an issue torquing their new ball joints to spec on the old chevy corporate axle? What do you folks think about the above procedure?
- Position the knuckle and sockets to the yoke. Install new nuts finger tight to the upper (the nut with the cotter pin slot) and lower ball socket studs.
- Push up on the knuckle (to keep the ball socket from turning in the knuckle) while tightening the lower socket retaining nut. PARTIALLY torque the lower nut to 30 ft. lbs.
- Torque the yoke upper ball stud adjusting sleeve to 50 ft. lbs. using Spanner J-23447.
- Torque the upper ball socket nut to 100 ft. lbs. After torquing the nut, do not loosen to install cotter pin, apply additional torque, if necessary, to align hole in stud with slot in nut. Install cotter pin.
- Apply FINAL torque to lower nut, 70 ft. lbs.
