79 c20 tire size help
Blue79
alberta
Caden
I am buying a 1979 c20 some time soon and I know It needs tires and I found some almost new 185/75r16 tires for sale would those fit onto a stock 2wd truck it also comes with rims that re 8x6.5x28 I think those would fit but am not sure
245/75R16, load range E are very close to the original diameter and load rating for a 8400 lb and up GVW truck. It’s also common to use 235/85R16E, which are slightly taller.
185/75R16 would be very small for a 3/4 ton SRW truck.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
My earliest data book is a 1983 edition.
The plain Jane C20 came standard with LT215/85R16 tires ( there may have been bias-ply tires on the '73-''79 trucks, but I don't have any literature/builder info going back that far).
The beefed up, HD chassis RPO CP6 came standard with LT235/85R16, as well as the Crew Cab C20.
Here's are nifty little tire size tools everyone can use to see the difference/percentage of using different tires:
<https://tiresize.com/> [Copyright by TireSize.com]
Yeah, 285/75-16 fits fine on a C20 on stock wheels and also later model stock wheels that are similar dimensions.
Blue79
alberta
Caden
Hi thank you all for the information it was helpful the deal did not go through unfortunately
ExtraZ
