78 k10 starter problem
Is your truck a 350 or a 400 by chance you know, or something else?
and you can just order a matching tooth starter for a 90s cchevy but you need to know what count your flywheel is
iamtherealJayy
Tennessee
V20, K10, K10
It’s a 350 supposedly. It looks like a 350 and all the 350 parts I’ve put on it have worked so far. But I haven’t checked the block and verified what it actually is. If I keep having problems I have another 350 I can drop in.
hoagster
California
K10, 1500
5.3l
I looked at Summit racing and there are 70 different starters that you can pick from based on bolt pattern, manual or automatic, and number of flywheel teeth.
iamtherealJayy
Tennessee
V20, K10, K10
How can I figure out the amount of flywheel teeth? It’s a manual transmission
hoagster
California
K10, 1500
5.3l
Read This, it will help.
I would pull off the alt and look at your engine code too and see if you have a 400. They have a special starter and flywheel i think.
Curt
Loco Hills
Curt
K-30
I haven’t read every post in this thread,but from experience I’ve seen a ignition switch/rod not adjusted or sticking causing starter to stick
iamtherealJayy
Tennessee
V20, K10, K10
I just completely redid the ignition, it was a universal ignition switch hanging under the dash when I got the truck so I just redid all of it. Ignition cylinder, ignition switch and rebuilt part of the column. The ignition switch might not be adjusted right but the starter was still having problems with the universal one too.
iamtherealJayy
Tennessee
V20, K10, K10
With the battery charged the truck cranks fine, ran like junk until it ran for a second(no choke hooked up but have one ordered) I let it run until the thermostat opened so I could mess with timing and carb tuning some. The truck is still running rich and quickly pushing the throttle down the truck sounds like it’s taking a quick deep inhale and bogs. I don’t know what the timing is at but I figure make a new forum and provide all the info on there so I’m not on here talking about it
Edit: also have new starter bolts on the way with the manual choke cable and a tachometer.
WFO
Texas Panhandle
If it is clunking intermittently and not turning over... you have a worn button on the starter solenoid. Pull the starter, undo the screws that hold the plastic cap on the starter solenoid and you see a round button on the bottom of the main starter wire lug. When you engage the starter, it pushes the round plate up onto that button and engages the starter. When that button wears down, you will hear the solenoid engage the round disk(the clunk you hear) but since the lug is worn down it doesn't make contact and the starter wont actually turn. You can unscrew the lug and turn it around so the unworn portion is now making contact with the round disk. This will be functionally equivalent to a brand new lug being installed and should let it keep going for another 20 years or so.
Eric,@Bextreme04 could this be the problem when the starter engages and spins the engine fine for a few seconds, then disengages while the starter is still spinning?
Or possibly the bendix, or both.
RanchWelder
Earth
Blazer
350ci
Older engines can leak water into the cylinders if the head gasket leaks around the #5-#6 cylinder and the rusted water jacket ports.
Some old blocks are so rusted, decking the block flat is impossible, where the water jacket seals the head.
AuroraGirl's recommendation to pull the plugs carefully and take a picture of each one, then post them here.
If the water jacket ports are rusted and gouged into the deck surface, OEM gaskets with a very wide fire ring, leave very little room for a seal.
If your piston is sucking in water, this would explain the starter finding a sluggish spot and the timing issues, starter kick back, etc.
Coolant will not comprress.
Compressing coolant can break your Starter Bendix and break ring gear teeth.
You MAY have to pull the heads and take a picture of the deck.
If there's a 1/16" rusted gouge around the water jacket port area near cylinders #5-6,
You might have the dreaded "Hydro-Jerk" AuroraGirl warned you about.
Last thing anyone wants (or needs) is a: "Hydro-Jerk"- AuroraGirl Copyright
Bowtie-dad
Wyoming
Brad
V35
7.4l
Are you running long tube headers? I had the same issue but only afternoon ran for a bit then it started doing the same cold or hot. If headers overheat the starter it'll draw hard but do nothing. I use a Wilson brand small body high torque starter now with heat shields and wraps.
ive had this problem with insufficient positive connection from the battery to starter (small engine, albeit), and wearing out starter. I could watch it because of how its placed on K series kohler.
PUlling plugs is smart, tho, so dont ignore ranch. But it would kick out, drive it shortly, then drop and then whizz but not drive nothing. Once replaced i found it also worked faster.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I had an issue not that long ago where I started the truck and the starter kept running and I shut the truck off and the starter was still spinning. I ended up having to yank a battery cable off. The problem is still un determined,
Im curious about this too. I've had this happen to me several times over the years, Usually happens when I've been cranking on it off and on for a while trying to start something. Sometimes it happened when the battery was low and starter was starting to sound like it's struggling. For some reason the solenoid must be hanging up? Maybe from getting hot ?
seanhatesregister
