Madhorn
- Jan 16, 2017
- AR-Arkansas
- Ken
- K10
- 5.3/NV4500/NP205/4:56 gear/35in tires
Well, here we go. Have the 5.3 apart for inspection. Everything looks good. Checked one main bearing and one rod bearing. They looked great and even got the thumbs up from my engine guy. So the bottom will be left alone. Will install a new oil pump, timing chain and lifters. As far as the top end goes, dropping the heads off next weekend to be gone through. Started reworking the harness this last weekend. My oldest son and I are making good progress. Since we are installing a manual trans, we have removed all the auto trans connectors and wires. We are using the instructions from Lt1swap. There are two wires I have question about. C1 pin 35 (CPP Switch Signal M/T) and C2 pin 18 (Clutch Start Switch M/T) I don't think my harness has these, do I need to add them?
