76 grill.
run2424
OKC
robert
It has the off set hood latch, and i can not find a grill. What other years will work? I have tried a 73 and 78 no luck there. HELP.
J Knight
Baytown TX
82 Chevy
350ci
You need to change the center grill support with center hood latch to use a 77-80 grill and you need to do the same to run the 73-74 grill as well as the outer grille brackets. What is pictured bellow is 73-74 only.
run2424
OKC
robert
Thats what i was a thinkin. Thank you.
firebane
Calgary, AB
Curtis
75-77ish?
78 and on
They all have different center braces. In 1977-1978 can't remember which year they also changed from the latch from the hood to the interior.
run2424
OKC
robert
I will look into that. Thanks.
run2424
OKC
robert
Found a grill, but one piece of the molding is coming off. Any idea how there held in place?
brentjo
