TheC5Surgeon
- Aug 2, 2021
- Panhandle of FL
- Matthew
- C20
Just got the truck home and started to dig into the hectic wiring situation. My electrical knowledge is admittedly pretty weak so I am learning as I go.
So a little background on the truck. At some point there was a second battery installed (unless some models came with two) along with subwoofers, amps, aftermarket radio/speakers, CV radio, and some other crap that I am in the process of tearing out. There are cut wires, damaged terminals, and degrading connections all over the truck. When looking at the fuse panel underneath the dash wires are shoved in behind many of the bulb fuses and there is a huge mess of wires tied around each other going to and from all the accessories.
There is a constant drain on the system because the batter would be dead after a day or so if left connected. Now I cannot get enough juice to start the truck even when leaving it connected to a trickle charger over night. The batteries are old and need to be replaced but I would like to figure some of the harness issues out so I can enjoy the truck while saving for the diesel swap.
My first question is mainly where to start on something like this? I have downloaded the 1976 wiring diagrams but they are pretty tough to follow. Any advice would be helpful.
I attached some pics of the wires going from the drivers side battery (the aftermarket one I believe). I can take plenty more of the engine bay and inside the truck as well if needed.
