750
yevgenievich
Place
Name
Year
Model
Size
Needle and seat replaced and idle fuel mix set back to stock. Also stuffed a bit of steel wool in to the exhaust. Rode around just a bit, but it likes to stall at low speed.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Did you use a wire in all the little passages? Mine had a lot of gunk and poo in them, even after sitting overnight in Chemdip.
yevgenievich
Place
Name
Year
Model
Size
I went the lazy route. Will probably get back to it with full disassembly if it is still acting up.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Yeah I've had some success just running fuel through them for a time.
yevgenievich
Place
Name
Year
Model
Size
It is slowly clearing up. Just letting it warm up and ride down the street a bit. It is still prone to stalling, so idle is set high.
yevgenievich
Place
Name
Year
Model
Size
This thing decided to somewhat give up. Was running this morning and suddenly just died to never start again. Has fuel and weak looking spark.
K201979
Winona, missouri
Hippie
350ci
Bad coils or loose connection maybe? Still feels like its got compression?
yevgenievich
Place
Name
Year
Model
Size
Has compression and spark is now fully gone. Need to start tracing the ignition side of the wiring. Was very random, just idling in the driveway and then no more spark
K201979
Winona, missouri
Hippie
350ci
I had that xv920 quit me at a gas station before. Took it all apart chasing wires at the station. Still couldnt get it n had a buddy trailer it. Long story short, it ended up being the kill switch wireing. The metal connecter was loose in the plastic conecter and had pulled in two without being visible. Maybe somethin like that. Sounds to me like a wire has rattled out of contact somewhere. Dont forget grounds too. Cant find nothin else id try another known good set of coils. Hope u gettit, good luck!
yevgenievich
Place
Name
Year
Model
Size
The kill switch is on a suspects list. Especially with elec tape poking out from the side
yevgenievich
Place
Name
Year
Model
Size
Still no go, but brake light switch is now fixed. Opened it and cleaned the contacts.
It does have spark, but looks weak. Supposed to look weak according to the forums. Good voltage at the coil. Seem to have fuel, draining fuel bowl on each carb pulls fresh fuel from the tank. But not even an attempt of fire.
K201979
Winona, missouri
Hippie
350ci
Only thing i can think of is fuel mix being altered by a vac leak or plugged carb passage. Or timing chain jumped(if ohc) but i feal like it would still try to pop off:33: idk but good luck.
K201979
Winona, missouri
Hippie
350ci
Good to hear u got it runnin. Be careful on old rubber!
jimlayhee
