Craig 85
- Jan 25, 2017
- Nashville, TN
- Craig
- K30 SRW
- 454/TH-400/NP205
I have no clue if the hangers for the other year truck you posted will work. You could use C30 or K30 hangers, but the K series are longer by about 2". The ones from the 14' bed should work. Measure your wheel base. It will tell you if you have a chassis cab or a pickup chassis. My K30 is 131.5". The Chassis cab is 135.5". Both are about 34" wide at the rear of the frame. You could get a Silverado package on a chassis cab.
Based on you pictures, I'm going to say it's a chassis cab. Do your inside dually wheels track with the front tires? If not, that is consistent with the chassis cab 14 bolt rear versus the Dana 70 in a dually pick up. The blue truck has a chassis cab rear end on a standard bed. You can see in the second picture, the Dana 70 requires the use of dually fenders.
Pictures 3-5 are my truck. You can see how the 4WD hangers are longer and put the springs under the frame. If you have a Chassis cab axle, your drums should be closer to the spring than mine.
