'73 Chevelle SS Wagon (local find)
Yes?
1&3/4 please.
Unfortunately, this adjustment makes no difference for me. I just got done trying that 1.75" setting, and everything from max short to max long. If I bend than rod a few more times, it will probably break, lol. No matter where it's set, the car drives the same.
Maybe I'm just supposed to burn gas and haul ass. It never stumbles if I simply mash the go pedal.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Oh yeah that's definitely how you need to drive it. Even my fuel injected stuff, I try to always drive them in such a manner, you know, just to keep them fresh and whatnot. It's good for them
Rusty Nail
Rusty
350sbc
Heavy on the whatnots..;)
Well Cubo, i'm pleased you agreed that was worth a look, it was the first thought equivalent. Bending carburetor rods is just about as old school cool as it gets!
Maybe we'll come up with somethin else to see..after we let that idea bounce around for a while. :waytogo:
Turbo4whl
Downingtown, PA
Wayne
I think Andy should replace the cap and wires as he said he wanted to do. By his own admission, Andy said the wires were shot. His now, high output coil, is pushing the spark current where ever it can go. Maybe cross firing the cap to a cylinder not under compression or even through the coil insulator to ground. You can't even see that happen like leaking wires.:waytogo:
Rusty Nail
Rusty
350sbc
Great "point".
Yeah and besides, there's no fresh pictures of that stuff so there's no tellin what's really goin on! *
All that jazz about the distributor?
Srsly wtf dude? Are we really meant to believe your vehicle hoarding ass aint got another HEI layin around? Cuz i'll tell ya right now Cubo, ain't nobody readin this, believes that!
:xmasorlyflag:
Help us, help you - lmmfao!
From a looks standpoint, yes the wires look terrible. But I guess that's a book that I shouldn't have judged by the cover. It runs so doggone smooth, even under load and when you wind it out. It really does run absolutely wonderful, other than the stumble at low rpm, tip-in.
Great "point".
:xmasorlyflag:
I've got bunches of HEI distributors. I simply didn't want to go that route because it would look "out of place" for this car, in my mind.
I got some pictures for ya though @Rusty Nail
Some of the chrome detail is worn off the cluster bezel, so I started touching that up with a chrome pen. I didn't get too far though, I'll have to finish the job on a day when my hands aren't so shakey.
See that Tailgate Unlock switch? Well, it didn't work. But now it does after fixing a broken wire inside the boot that goes to the hatch. Also, the radio and headlight knobs were super gooey and decomposing. They got replaced with ones that are chrome/simulated wood. They decently match the door panels.
Didn't do much today. I only rolled the windows down and replaced the upper radiator hose. The old hose looked like it was about to explode after I ran it yesterday.
Fun fact, a '77 K10 hose is the exact perfect length and fit.
Rusty Nail
Rusty
350sbc
Makes me wonder if there was a "more" desired or updated, 2bbl factory ALUMINUM intake manifold that could be ripe for teh swapping..you could even paint it rust colored if you like but I kind of see what you mean with that short-bus distributor...lemme look around in the garage next week mebbe I can produce a donation...I got some parts like that layin around.
Turbo4whl
Downingtown, PA
Wayne
.... and replaced the upper radiator hose.
Of course it does. GM's parts interchange between vehicles was tremendous in the '70s. Every full size sedan and light pickups had the same D52 brake pads. Use the same high output SI-10 alternator on most everything, by just re-clocking it, just to name a couple things. We all know how easy it is to swap engines between different models.
billbill321
