86 C20 - Climate control not changing position - cable or vacuum operated?
kapitein
Netherlands
Alex
C20 Suburban
Hi,
I know this is a well traveled road, in fact there is so much info, sometimes its difficult to pick out what you need.
After spending $1000s I have beatiful ice-cold AC in my 86 C20 Burb. However, all that air is going straight to the floor. When selecting the different modes on the dash control the AC compressor will switch on/off correctly according to the position, but the rod that actuates the big door behind the glovebox doesnt move.
I can move it freely by hand, and the door(s) open and close correctly without interfering with each other.
Is that rod assembly actuated by vacuum, or is it cable operated (and therefore im missing a cable...) All my vacuum lines appear to be connected, but I cant 100% say its all correct as someone has been messing around in the last 40years and who knows what they did.
Anyone who has been through this before, would love some advice on how to get the mode select working again.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Also make sure the vacuum is connected in the engine compartment. My 1989 has similar issue (although the A/C doesn't do much anymore) with the routing doors. Turned out the vacuum line ging through the firewall was broken, so none of the diaphrams that move the doors did anything. The heat blend door still worked because it is cable operated.
kapitein
Netherlands
Alex
C20 Suburban
So far Ive found some fun stuff.
The vacuum supply from the engine bay, well that was holes up directly to the cruise control diagphram
So that's now temporary connected to permanent vacuum on the carb (bypassing the vacuum pot)
This improved things slightly in the interior.... But I still can't get those doors to move (and therefore no air from the middle vents).
I found this hanging behind the dash... Does anyone recognise it?
350 w/203
You found your problem!
Auburn, Washington
Yup. That goes to one of the vac ports on the hvac box. If you take off the glove box door and remove the glove box most of them are pretty easily accessible.
Removing and reinstalling the whole thing under the dash is one of those cuss for 2-3 hours the first time and much easier when repeated.
McNeal87
