700R4 shifting issues
fallguy
Minot, ND
Jamie
Silverado K10
Here are my issues:
1. tranny constantly shifts at even the slightest inclines driving down the highway.
2. tranny hits hard from 1st to 2nd...KACHUNG! let off on throttle just prior to shift and it lightens up a bit.
3. 4th gear...what's 4th gear!?! I have to be climbing a mountain with my foot in the engine to get it to shift to 4th and it hits hard too.
TV cable adjusted, oil/filter changed, stuck accumulator fixed...all done by certified tranny shop.
HELP! Any ideas?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Here are my issues:
HELP! Any ideas?
Whats your gear ratio and tire size? 2 or 4 wd?
fallguy
Minot, ND
Jamie
Silverado K10
3.42 with 33" tires K10
Boone83K10
Boone, NC
Benjamin
if it's an aftermarket carb.. do you have a TV corrector on it? Correct bracketry?
Mattchu60
Iowa
That sounds just like my Trans in my 87' - Pretty sure mine is starting to go as I felt it slipping a little the other day.
Never gets into OD unless going down a hill. I have 3.42 gears with 33" tires as well. I started just running in D instead.
Hoping my Trans lasts, the TV cable has been adjusted but I think its too late. Probably looking at a TH350 swap for me as I dont use OD anyways.
Jims86
Patterson,Ca
5.7 TBI
33 s are a little on the big side for 3.42s. 700r 4 s dont like real low rpms and that kind of strain. 3.73s at least, or no bigger than 31.
Did this just happen all of a sudden, or has it happened gradually getting worse and worse?
Not that it matters alot since in whichever case, the hard shifting and clunking or hard hitting going into gears usualy mean the trans is short lived. Sometimes for worn clutchs and the pistons to compress the clutch packs are out of spec, and the piston is traveling further to compress the clutch pack, and traveling further with high pressure, then it hits harder. Other causes is stuck boost valves or leaking valves.
And in your #1 symptom, do you mean it's constantly DOWNSHIFTING???
And 4th, you have to be CLIMBING, not going down a hill? Some of this makes no sense is why I ask for specifics.
fallguy
Minot, ND
Jamie
Silverado K10
I'm headed to 35's with 4.10
fallguy
Minot, ND
Jamie
Silverado K10
Always been this way, not getting worse...just is the way it is. Yes, it downshifts at the slightest incline. Was told to change oil and put in a new TV plunger/sleeve & spring (Sonnax Performer set)...so I did..no real change though.
I have a feeling it's not downshifting, being the lock up is vacuum controlled, I have a feeling it might just be unlocking the converter. Which is somewhat normal. The second you start an incline the motor will feel the strain and lose some vacuum.
brentjo
