700r4 shift points
MadOgre
NA
NA
NA
NA
NA
post a pic of your throttle linkage
350runner
tx
Ceasar
It should stay locked in position once the button is pressed back in place. Pics would help.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
I will get some tomorrow evening.
Sent from my Nexus 7 using Tapatalk
flyboy1100
UsA
me
k1500
Sent from my SCH-I605 using Tapatalk
flyboy1100
UsA
me
k1500
Not the best I can get more tomorrow
350runner
tx
Ceasar
Need a couple of this area
flyboy1100
UsA
me
k1500
OK, tonight. I can pop the cable out quick too
MadOgre
NA
NA
NA
NA
NA
So you for sure have at least one notch sticking out after its adjusted ?
flyboy1100
UsA
me
k1500
flyboy1100
UsA
me
k1500
Cable is taught at wot. I can't push the adjuster back in without pushing the button.
flyboy1100
UsA
me
k1500
bump
MadOgre
NA
NA
NA
NA
NA
Did you change your cable out yet ?
flyboy1100
UsA
me
k1500
Not yet. never got a response since i posted those pics. haven't been home either to be able to do anything
looks like the right cable?
MadOgre
NA
NA
NA
NA
NA
I got mine from GM and its pretty much the same except mine looks a little beefier. I don't think you have any thing to lose by changing the cable.
But I was wondering what gears you are running with what size tires ?
cause I don't know if your numbers are to far off for shifting. But your cable should stay put after adjusting it.
These transmissions are ideal with 3:73 - 4:56 gears
flyboy1100
UsA
me
k1500
current tires are 31x10.5, next week will be putting on 265/70r15's (29.6" tall, or 1.2" shorter than current). 3.42 gears.
honestly the replacement cable only looked marginally cheaper than the one that was pulled off. if i adjust the cable towards the back shorter than the WOT setting, it pulls back out. but as i understand it, it is supposed to do that. it won't go towards back unless i push the button.
i didn't have the tach until a month ago so I have no idea what they were before, but it feels about the same as what I had with the frayed cable
blue900
