- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
More line pressure will also blow seals. I have a feeling the 3-4 pack had been overheated before, hardened the seals, sythetic fluid being to thin, leaked past the seals. IF you haven't let it slip much, or overheat even more, a trans conditioner additive as much as I hate to suggest it, might just swell those seals enough that that they will work again. Its worth a try, or another secret I hate to suggest, with nothing to lose, try a pint of brake flluid. But, warning you know, brake fluid is harsh on the clutches, but it WILL swell the seals. IF the clutches aren't junked up yet, and just the seals are cooked a bit, the brake fluid will soften and swell them up. DO NOT use more than a pint. IT will either do the trick or it won't. But honestly, if it comes to the brake fluid trick and it works, its just a band aid and the trans is short lived. I'd say check the goveernor, but when you suggest, it acts like when it goes into the 3rd, it just starts to freewheel or slip, its not the governor. IF it wasn't trying to go into rd at all, then yes I'd think governor. TV cable or wrong elecrical wiring would have been your only hope of a fix IMO. Does the pan have a drain plug? Drain out the synthetic and put in Dextron/Mercon. Systhetic is only for GOOD, almost new transmissions, or KNOWN very well good condition transmissions. I've never been a big fan of synthetic fluid anyway. Not in an auto trans. Auto Trans fluid is good **** as is, and there really isn't alot of friction in an auto trans, not like rings scrubbing a cylinders walls or babbit metal crank bearings. Thrust washers and torrington bearings are slow wearing as it is. Keep them cool and clean and they can last just the same as Synthetic fluid kept cool and clean.
