700r to 480l
hiltijoe
ny
joe
custom delux
heres my deal I'm putting a 454 in my 87 v20.the motor came out of a 93 burb.i have the transmission and t case out of the burb.i want to change to the transmission out of my truck to the the transmission from the burb.will it fit to my t case??
CSFJ
If I remember correctly, after they went to the round pattern adapters, all the round patterns interchange. The only catch will be the spline count on the output of the trans and t-case input.
Camar068
10 yrs Air Force
the 93 transfer case is drivers side drop correct? The 4l80 is 32 spline output shaft. You need to find out what spline count your existing transfer case or transmission is. If your current trans is a 700/r4 or th350 it has 27 spline.
If the spline count is different then you can change the input shaft on the transfer case to match. After you've figured that out, figure out what adapter you'll need.
What transmission and t-case do you have in it now?
hiltijoe
ny
joe
custom delux
700r4tranny so I will need the adapter then .where can I get that?
yevgenievich
Place
Name
Year
Model
Size
If you happen to find a 91 3/4 4x4 suburban it will have it. Otherwise, advanced adapters, or as mentioned above
Battlac40
New Mexico
James
K1500 Sierra Classic
Pretty sure you are still going to have a spline count issue unless you change input shafts on tcase. What cross-member are you using?
Derick C.
Auburn WA
Derick
454/700r4
I have a 700 but if I had the money I would use a 4L80
hiltijoe
ny
joe
custom delux
total change .making it a carbureted motor with a th 400 built
Wildjoe330
Right Now
wildjoe330
Itbp
I have a core 700 I was wonderin what to put in along
with my new 205 even a fuel injected 350 replacement
without computers?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
What is the VSS ?
Vehicle Speed Sensor. A 4L80 needs a signal to know when to shift, comes from the throttle position and VSS.
Shift... I meant shift...
yevgenievich
Place
Name
Year
Model
Size
For 4x4 the computer needs vss from the transfer case. 4l80e has two speed sensors, input and output. The rear one was used in 2wd applications and in 4x4 applications the one on the transfer case should be used. On my 91 all three are used, but probably brcause it was the first year for the trans.
Wildjoe330
Right Now
wildjoe330
Itbp
sounds like that would leave my 77 K20 out of it.
rljohnson013
