65 c30 - Dually Tension/Retaining Ring Questions
nbkk43f
charlotte, nc
Nick
Hi - I have a 65 c30 that I converted over to a 14 bolt dually rear axle. I have two tension/retaining rings (1st and 2nd pics) that I assume go on the rear axle to allow for the conical style lug nuts to seat properly. However for the front end (3rd pic) - I did a late model 1ton (I think that's what it was) squarebody swap - do I need the tension ring to properly mount the front wheels, or do I just go with a "flat" style lug nut, if there is such a thing? It's been quite a while since I did the front and rear swaps (other projects creeping in) and I can't remember (getting old :) ) how the wheels were originally installed, the front end didn't come with any wheels installed. I've located information regarding the rear tension ring, but can't find much about the front.
Thanks in advance for any guidance!
bluex
Spartanburg SC
C15
The squares I've had/worked on an my 99 dually all used the ring and conical nuts for steel wheels. Aluminum wheels (like alcoas) usually get the lugs with the integrated washer.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I think it all depends on if the wheels are hub or lug centric maybe. Im pretty sure There's some variables. I've done unsafe things with wheels and learned to do the research like your doing.
squaredeal91
Greg bush
1991 SB
My 91 dually uses the rings. I think even up front it did. I now have different front diff
Rickf
Grafton NH
1974, 1954 & a 1937
My old '84 and '93 K30's were both 6 tire one ton's and had the style wheel you've pictured front and rear & used the ring. The '93 has 14mm studs and lug nuts that are set up for hub caps.
nbkk43f
charlotte, nc
Nick
Gotcha - sounds like I need to round up another set of rings for the front. Thanks for the information!
nbkk43f
charlotte, nc
Nick
Thanks, @Rickf!
Sharon
