6×9s
Doppleganger
OH-MI: Just like it sounds
The depth would never be an issue - but the rounded corners touching the edges of mega-magnets could be. I saw a 4" speaker high up in the B-pillar once - looked almost factory. Might be a way to put components between the cab corner and the B-pillar.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Yes with Kicker 6X9’s
Scribbles
az
The magnet size is determined by power handling and magnet type. If you aren't planning on using an amplifier then a bigger magnet will just take away from the sound as you won't have enough power to run the speakers correctly.
If you are planning to run an amp then I usually do like 45tt and build a basic speaker pod out of 2 pieces of wood that fits what you are installing and cover it with matching carpet.
it shouldn't be much at all like under $20 to build both speaker pods.
Feel free to ask if you need any more help. I have been an audio installer for almost 30 yrs and have 2 Squares plus built 15 or so nice Square trucks.
This is the only one on this computer but it came out nice even before paint.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
I use Brother's bracket and Fosgate 6x9 work great sound good no clearance issue ;)
Z28 Guy
mississippi
Jermaine
Are you guys running amps or not?
WFO
Texas Panhandle
I'm running 2 Alpine 2 channel amps that I bought new in 1989. 1 for the front speakers, and 1 for the rear. Plus a cheap Kenwood 2 channel amp, bridged, for a single 10" Subwoofer.
I'm not into thumpin, but using a sub helps keep the other 4 speakers more bright sounding.
Randy and Easton
Randy
C-10 LWB
Z28 Guy
mississippi
Jermaine
TPI-C10... do you exactly what series RF the speakers are ? Rockford offer 5 different 6×9 speakers. Some are more shallower than others as some sound better than others
Randy and Easton
Randy
C-10 LWB
Yes
1980_L7
So cal
Herman
400 sbc
How bad does putting the 6x9’s in the corners behind the seat drown out the sound?
Camar068
10 yrs Air Force
not that I spend a lot on sound or is it as loud as some of the stuff above, but I currently have JBL 4x6 (cab corners) with a 90's kenwood sub behind the seat. Plenty loud for me and sounds good. Upgrading to 6.5 component in the corners in the next day or so. Can hear the high/mid/lows just fine currently. Obviously if you want the highs in your face, then move the tweeters.
Then again, my level of good is probably lower than yours. Keep reading lol.
Burban90
