500 cfm edelbrock enough?
KnockingDiesel
New Mexico
TJ
I ordered a GM goodwrench 350, 240 hp, for my truck. Nothing fancy, just gonna be a daily driver (for when the CC/LB DRW feels to hard to drive), should not see anything above 4500 rpm tops, half that cruising.
I came across this formula, CFM = Cubic Inches x RPM x Volumetric Efficiency ÷ 3456. It was also stated that 75-85% volumetric efficiency is typical. I went with 85% just in case
I did the formula and 350 cubic inches @5000 rpm needs 430.41 cfm @ 5000 (redline).
Does that seem correct? I have a edelbrock 4 barrel performer intake (edelbrock 2101 idle-5k rpm) and a 500 cfm edelbrock electric choke carburetor. Both are nib left over from a project.
Any info or replies will help!
Btw I Know what too much carb feels like, when I was looking for a truck i drove a 305 with a 750 cfm, it was not drivable.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
500 CFM is a good way to go, and your calculations are in the ballpark. I'd say if you wanted a Quadrajet, you wouldn't have to worry about any of that, but you've already got the intake and carb so go for it!
vkh
Western Montana
Var
C2500
I've heard of plenty of people run 600 cfm edelbrock carbs on 454s, that carb will be just about perfect.
74 Shortbed
I ran a 600 on my dually with a camper and towing the boat, works great, the formula above is correct, a 600 is plenty for anything under 4000rpm...
KennedyGS
