5.7 vortec timing
Gbow
SC
Gregory
350 vortec
Well after some considerable searching and trial and error I have found the issue to be my qjet. I needed to adjust the secondary air valve. It was opening to quickly and leaning out my fuel mixture. Now I am swapping jets and metering rods to make the engine run like it wants. The trans is shifting weird but I don't want to mess with it till I get the carb right. Thanks again for your help.
geolee
illinois
george
just reading the thread and lil late but to find tdc take ur spark plugs out when rotating the motor over and use a hose that fits perfect into the #1 spark plug hole and put a dog toy squeaker in the end of the tube. when its at tdc it will start squeaking. easiest way to find tdc....
roundhouse
atlanta ga
justin
77,78,79,80 ?
I never bother with the timing marks
I just find a hill and time it by ear
Advance it two degrees and run up the hill at full throttle
Advance it two degrees and repeat until it pings on the hill them back off two degrees
If your truck is a automatic trans You can also do it with a helper advancing the timing while you brake torque the engine
You can also set it with a vacuum gauge
cahillasher76
