iamtherealJayy
- Nov 26, 2021
- Tennessee
- Jacob
- 1987, 1978, 1976
- V20, K10, K10
Yes the clutch should be clearing I can turn the crank with no clunking or binding. The first two links you sent seem to be the same lol, the manifolds clear but the down pipe afyer the 02 sensor goes straight into the frame. No wires are back there I’ve yanked plenty of wiring out of frustration. I also broke my original throttle cable trying to get it to uclip from the firewall. Also dented the firewall with the bolt I had the chain on for the cherry picker. I’ve had a lot fighting against me. What size clutch should I be using? I went with a 1978 Chevrolet k10 factory replacement 12” clutch. It was the “factory replacement” I had the option to go to an 11” but I chose factory replacement. My sachs1050 flywheel claims to work with an 11 or 12. So far everything that could cause an issue has caused an issue. And I haven’t even started wiring or fuel system stuff yet…
