5.3 or 6.0 ?
4WDKC
Southern Florida
Kacy
1979k10
Nevada
Dave
fried_daddy
Elkmont, AL
R1500
5.3 LS
I have a guy in Ohio who does them all day for under 1k for engine and trans, he'll ship via Fastenal as well, it's less than 200 bucks there.
You still know this guy? Currently looking for a LS to get prepped to swap into my 87.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Yep, he's in my Driveway Engineer Facebook group, his name is Jason Brown.
roundhouse
atlanta ga
justin
77,78,79,80 ?
I'm not on facebook. Ok. Thanks for the info. I'll keep looking locally.
Find and buy the entire donor car
Wrecked Tahoe’s are plentiful
Do NOT NOT NOT buy a engine that you can’t hear run and do a compression check
I got burned bad buying a engine already out of a low mileage pickup
And whoever takes out the engine will hack up the wires and break connectors
And if you want an auto overdrive trans you need to get the one with the engine , they changed the software so often that you need the trans that came with the engine
I found the VIN on the engine and ran a car fax
It had 278k on it when it got totaled
Camar068
10 yrs Air Force
what part of OH? More info please. Be good info for next swap or when this one goes out.
Camar068
10 yrs Air Force
You will need a tank and a different pump and some expensive fittings and hoses
I found out after the fact that there are cheaper ways instead of using AN fittings.
Jrgunn5150
Ionia Mi
J.R.
6.slow
New Holland Ohio, but he's really not unique, there are a half dozen guy's parting out GMT800 trucks daily around me in Central Michigan. Two of them I know of will happily load whatever onto a pallet and drop it off at a Fastenal.
Where there's a will there's a way.
I get in my truck and drive 12 hours south to pull rust free panels, I can't figure out why people don't do the reverse, other than they just really don't have the will.
roundhouse
atlanta ga
justin
77,78,79,80 ?
I didn’t use any AN fittings and it still cost a bundle for the tank and pump and hoses and filters and fittings etc
roundhouse
atlanta ga
justin
77,78,79,80 ?
Pick it up in person AFTER you hear it run ,
I’ve bought two engines on pallets and both arrived with missing and damaged parts
One was missing the front accessories and after several phone calls did not resolve it , I had to have my credit card company do a chargeback which magically got my parts delivered the next day
Second place hacked all the wires and connectors and cracked the oil pan, valve covers and smashed the starter and some other stuff
As well as lying about the mileage on the donor
If you have the space , just buy the donor vehicle and pull the engine yourself
Or pay one of your buddies with the space to pull the engine .
If you buy one on a pallet long distance , you’re gonna get ripped off .
Jrgunn5150
Ionia Mi
J.R.
6.slow
I've had fine luck buying them on pallets, I've also sold them on pallets.
You win some, you lose some I guess.
I do agree a total donor is a good way to go if you have the space.
Hugeroost
Kyle
Hurricane Harvey ruined 2 of my trucks w LS motors. I bought 2 from Patterson Wrecking at 400ea, both came wrapped in plastic on pallets, one had 70k the other82k. Both still going strong, he is on eBay and guarantees his motors. If the donor truck is not too badly damaged he does a video before he pulls it. He also sells the starters, alternator, etc for 30 bucks each...Roost
Frank albrecht
Wisconsin
Frank
Turbo LS
What’s the benefits for both I’m thinking about swapping from my worn out 350.
What’s the easiest way donor truck or buying separate?
I would do donor truck. There’s tons of little parts you will need along the way.... I did the LS 5.3 in my 86. I didn’t go for towing I’m shooting for more street in mine. I also did a turbo setup in mine which is farely easy if a guy has a weekend.
jlyon1006
