454 rebuild cost.
76chevyc20454
Indiana
Justin
I'm about to tear down the big block for my 76 c20 and see where the knock I am having is coming from. How much does it cost to have a stock rebuild done. I realize that it's different everywhere and depends on how much machining has to be done. Just trying to get a idea. Thanks in advance.
87scotty
Central il
Andrew
V20
5.7 for now
1500 give or take there are some ready free things you can do to help it out a lip bit for power
74 Shortbed
Lot depends on how much you can/want to do yourself..
87scotty
Central il
Andrew
V20
5.7 for now
That is true only thing I have the blockshop due is inspect and machining and I tear down put it all together
76chevyc20454
Indiana
Justin
I'm going to disassemble myself and I'm wanting to assemble but don't have tools to check bearing clearances. I'll prob have them install cam bearings just because I heard that can be a pain. This will be my first build so I'm going to take it slow.
74 Shortbed
Cam bearings are easy but you need the tool to install them and it's not cheap, if you're not gonna do motors all the time better off letting the machine shop put them in, just make sure that they clean all the oil passages first.... Yes, don't rush or it could cost you double down the road..
Jarhead79
Mt Vernon il
Michael
You can rent a cam bearing tool at oreillys, then return it for refund
74 Shortbed
Didn't know you could rent them, I bought mine many moons ago..
PDlane200
