MikeB
- Apr 4, 2014
- North Texas -- California escapee
- Mike
- C10
FYI, adding only dropped shackles or dropped hangers will change the drive line angle and move the axle a little forward (with hangers) or rearwards (with shackles). I did just the hangers and had to get my driveshaft shortened and then use pinion angle shims to tilt the nose of the pinion back down 4 degrees. Believe me, that was no fun. Had to make some longer spring locator pins to work with the shims. If I had a do-over, I'd opt for 2-inch "dropped" springs.
Mr. Gasket shock extension (left) shortened and machined to use as longer locator pin to accommodate pinion angle shim.
