$4, $3, $2, $1 Wholesaler Closeout Wipers at RockAuto.com
RockAuto
Preferred Vendor
Preferred Vendor
Madison WI
RockAuto
5.4L
A competitor switched suppliers for their private label wiper line and created one of the best Wholesaler Closeout bargains for RockAuto customers ever! First-quality wiper blades and refills made by Trico, including the latest "beam-style" blades and specialty products like Winter and Teflon blades, are now available priced under $4.
Examples:
$1 or less for OE Metal Refills and Twin Rail Metal Refills
$2 or less for AeroVantage
$3 or less for Heavy Duty Blade, Winter Blade, Exact Fit, and Winter Teflon Blade
$4 or less for Teflon Blade, Classic Blade, Teflon Shield, Innovision, Contour BB, and Neoform
Some of these wipers made by Trico originally cost more than $20! It is the perfect time to replace the wipers on your vehicles or stock up on the wipers your customers will need if you're a professional mechanic. As with all Wholesaler Closeouts, quantities are limited so get them while you can! Find wipers for your vehicle under "Wiper & Washer" in the RockAuto catalog.
www.RockAuto.com
What would you say shelf life is for wipers provided they stayed in their package and on the shelf in a garage?
I normally replace wipers due to weather exposure and not use because I have so many vehicles. They get dry rotted or stiff and don't wipe for crap. So I have to buy new ones for the 1 time I end up driving on a bad weather day.
Being most of my vehicles are squares, maybe I can stock up on several sets.
RockAuto
Preferred Vendor
Preferred Vendor
Madison WI
RockAuto
5.4L
They will usually last quite some time if they are kept indoors and out of direct sunlight. As long as they are not exposed to the elements there should be a reasonable shelf life.
Thank you,
www.RockAuto.com
ben_swager
