84prspctr
- Apr 5, 2023
- ca
- ben
- k10
I know the fuel mileage shouldn’t be that bad. Every time I take the truck out I’m stopping at the gas station at least twice, which isn’t making the wallet happy with gas being over 5 bucks a gallon. Timing is set to 12 degrees initial, carburetor is fine tuned with vacuum gauge, idle mixture screws are about 1.5 turns out. Accelerator pump on second notch. Edelbrock 1406, hei distributor with accel super coil, none of the valves seemed loose or out of adjustment. Holds timing steady no jumping or anything. 35” tires lifted 6 or 7 inches, turbo 400, 350 engine, Holley contender intake, stock mechanical fuel pump, no emissions, hooker headers. I’m running about 1/3 throttle going 65 on the highway. Is there a way to tell if my vacuum advance is messed up?
