350 Chevy knocking noise!
eskimomann209
Modesto
Marcus
You drive it 3/4 of a mile?
Maybe drain the oil and see
There’s a company that also accepts engine oil and runs an analysis on it to determine amount of metal inside if you can’t determine yourself
I have used black stone labs where I used to work
Might be worth the 30 bucks to see what’s going on
78C10BigTen
pennsylvannia
C10 BIG TEN
I like how the guy in the vid says its a piece of junk generic 70s chevy truck.... hey pal how bout you go F yourself!!!! Id LOVE to have a 73 square in that nice shape, horrid knock or not!!!
76-77-78
Garrison ND
Ethan
Yeah I know what you mean I know some people that just sent 2 squares to the junk yard!! one was a 79 k20 with the original 400 abc that still ran and was almost rust free. And the other one was an 80 something k30 dually with a 454 also running this one had some rust and dents but still what a waste of 2 great trucks imo
The truck in the vid is not mine just a vid I found with the exact same sound my pickup is making my truck was an original 350 4bbl truck with a manual and is still a manual but I’ve had enough suggestions to check that so I guess I’ll man up and lay in the melting snow for awhile and look the clutch and flywheel and bellhousing bolts just to make sure they aren’t the problem
And my bad, again in a hurry, skimming and not paying attention. Having a flywheel for a manual trans eliminates the assumption of a flexplate that goes with an auto trans.
They should be arrested and charged. That's criminal.
4WDKC
Southern Florida
Kacy
^Agreed
You didnt change the oil after getting stuck in a lake? HOw deep were you in the water? Did you check the oil to make sure its not filled with water?
76-77-78
Garrison ND
Ethan
^Agreed
I was not in the water I was stuck in the 2 feet of snow on top of the ice. But yeah I would have a whole bunch more issues if water would have been involved
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
i'm with Snoots, a broken rocker arm can sound very serious.
Big Chip
Michigan
Kevin
C35
I had a rocker arm turn sideways that sounded horrible. I’m with checking those first.
Jerry phillion
Saginaw, mi.
I think you have a bad hyd lifter. I had one yrs ago that only had 15 K Miles on it . It really pounded. Put new lifters in and problem gone. I would also drain oil and ck for metal shavings first, or with that good oil pressure, I would start engine and watch rocker arms and feel them for loud noise as it runs. it will tell you what may be problem. It will also tell you if you are getting oil to rockers. Good luck and let us know.
jlyon1006
