Knocking noise in D and R after high revs
NickTransmissions
Las Vegas
Nick
R10
This was it. Don’t hear the knocking anymore but if it happens once… it can happen twice. Is there something I should do to keep them from backing out again?
How tight in terms of lb ft did you torque the bolts?
Did you inspect the threads at each mounting pad on the converter?
Truck82
Alderton
Christopher
35 ft lbs.
I didn’t inspect the threads on the mounting pads. I probably should have done that first but all three bolts were loose so I just went ahead and tightened them down.
NickTransmissions
Las Vegas
Nick
R10
35 ft lbs.
That's the correct spec, I believe. Some blue loctite on each bolt also helps. If they come loose again, replace the bolts & put blue loctite on the new ones. Also check the crank itself for any irregularites in that event.
If they come loose a third time, either helicoil the converter threads or replace the converter
Truck82
Alderton
Christopher
Thank you, I appreciate all the help. I’m going to be rebuilding this engine soon so I’ll make sure the crank and everything is working properly
NickTransmissions
Las Vegas
Nick
R10
You're welcome...given the converter came loose, you will want to inspect your Th400's front pump and bushing/seal once the engine and trans are both out. In fact, I'd overhaul the transmission completely if it hasn't been rebuilt in the recent past. This would be good to do especially if the engine will be making a lot more power after the rebuild.
Truck82
Alderton
Christopher
It was rebuilt by a shop my grandfather worked at about 25 years ago but then he let the truck sit right after that. It probably has around 1,000 miles on it right now. I wasn’t going to do anything to it when I rebuilt the engine except for a different TC. In the spring I will be going through transmissions class so hopefully I will have a little experience and won’t be so intimidated by opening up a transmission.
NickTransmissions
Las Vegas
Nick
R10
Awesome, man! Great to hear you'll be taking transmission building classes...You can get ahead in your studies, if you'd like by checking out my TH400 Information Thread, if you haven't already seen it. I have compiled quite a lot of info there, would be a good resource for you.
Truck82
Alderton
Christopher
Great, I will definitely be checking out that thread. I will also check out your YouTube. It looked to be really helpful.
Thank you again
Sad Sack
Omaha, NE
Goober
C15
Blue Threadlocker, and be careful when pulling out Convertor to meet flex plate, you don't want to be just "grabbing" the front pump.
sam s
