- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Thank I appreciate this. I would think the model/brand of spring would become important, as the rear eye would have to be on the small side to fit in there. I've heard of notching the frame for spring eye clearance. If using the stock forward spring mounts, I imagine is could be shimmed to hang the spring a little lower to compensate for lowering the rear of the spring. It would certainly get tight quick with an arched lift spring, as it not only moves back but up.
Sure, anything can be done with a flame wrench, big effin hammer and the right attitude I guess..
I would also be concerned about the clearance between the spring/axle mounts and the bottom of the frame. The 4x frame has a little more clearance in this spot too. But with a lift spring this would become a non-issue.
I think there might be a few other issues to deal with. For example (I think) the rear cab mounts on a crew cab 2x are different than 4x crew cab.
And take note this conversion you were so kind to show would only work with stock length springs. a long spring like a 52 would need the front mounts moved more forward. I believe the whole concept is really about hanging a longer spring for massive travel... which in reality is just more droop. Droop is where it's at in keeping tires on the ground!
Right, the spring eye size could be a big factor as well, but I think most of the good (softer) springs tend to have eyes on the smaller side. And yes, bigger lift springs with more arch are going to 'grow' much more, but they also tend to be on the shorter side when installed at ride height, which pulls the shackle forward and gives it more room for travel during compression. But a 1/2" longer shackle makes a big difference too, I neglected to take pictures of that.
Don't get me wrong, it's certainly a lot of work to convert. None of the correct holes are there, all the brackets are different and the 4x4 crossmember ain't gonna fit without at least minor modifications. It's a frustrating pain in the ass for a lot of people, but it is doable and can work.
