Powerhouse Ranch
3G Connoisseur
- Jan 6, 2021
- PA
- Luke
- 1980 & 1988
- C25 & V15
- 454 & 350
Yay! Yet another speedo thread! now i checked around the forum already but none quite touched what i wanted. I also briefly touched on this in my "350 TBI Not Running Right" but decided that this s**t-show deserves it's own thread. I NEED AN ANSWER!
Way back when my speedo/odo stopped working. Alright, did a quick diagnosis: cable still plugged in both ends, put a drill on the tranny side, speedo bounced. Okay, good. So the next answer is to pull the tail housing of the SM465 and see what the deal was. Well, i didn't necessarily want to, so i didn't. Fast forward a year and a half later, i have the rear pinion seal out and the tranny output shaft seal out. Figure i should probably do this while the driveshaft is out. Alright. . .
So i pull the tailhousing. Speedo gear isn't damaged and it spins freely (should it?) the "drive gear" on the output shaft, pulled right off (should it?) Should something have been holding that tight against the tranny? Was i missing clips? Did it wear loose? It isn't damaged in any way. . . THE POINT IS is that it worked! And then all the sudden it didn't, and never has since, not a wink! No remains or chunks of possible clips when i drained the housing.
WHAT THE HELL HAPPENED? What am i missing? Pictured below is the gear that slides right off and that makes contact with the other speedo gear. Pictured IS NOT the SM465 or mine for that matter, just a google one i grabbed real quick, just to show the gear.
