2 wheel drive s10 blazer
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have ordered so many parts for this build I get boxes on my door step every day. and its a surprise whats inside.
got the hypertech power charger and tbi spacer and the b&m mega shifter
I got the rear 3'' blocks installed and painted the front spindles
I have a lot of parts to install and more on the way.
cowl hood and new gmc grill on they way
I need to start getting some pics of the progress
Is this your first Ratchet shifter???
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
nope why
Just curious. I've had 2 in the past. Love and Miss them. I ran the QuickSilvers. Might try Mega the next time. The shifters to get is the Mega or the Quicksilver. They both have the same features, but are a bit different. The Mega has the lift T, the Quicksilver has the lift stick.
Both are 3 and 4 speed auto compatible, both are ratchet, and both are reverse valve body compatible too. Both also fit GM, Ford, and Dodge too.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have had some hurst shifters and multiple b&m shifters
I like the star shifter I have one in a 63 c10 its fun to drive
Swims350
Logan WV
none
you're getin parts in and putting back together I'm still removing lol.
I am about to remove the upper control arms and steering stuff most likely. The one lower is already off, made very easy access to the motor mount bolts, the other is loosened up but not off.
just wished i had a ton of new stuff coming in.
I need a trans and a shifter for mine.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
<iframe width="420" height="315" src="//www.youtube.com/embed/J9Lx7chd5X8" frameborder="0" allowfullscreen></iframe>
Stewzer55
Ohio
Stew
R30
[yt]J9Lx7chd5X8[/yt]
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
thanks I messed that up I was in a hurry
I was trying to say its alive I got it fired up today
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have a new problem to figure out my exhaust
I am thinking about running a dual 2.25 in/out flowmaster 50 series they don't have a 2.5'' dual in/out muffler or I would run it.
there is not room on the driver side for the pipe to exit with out a lot of work.
so I am thinking about running the duals basically like the stock single is ran. it dumps out behind the pass. side rear tire.
I might look at running two mufflers standing up side by side. that depends on how much room I have.
if it was a truck I would just dump it behind the axle towards the ground. but being it is a blazer I want it to exit out from under the body.
Swims350
Logan WV
none
that's how the v8 exhaust kits for s10's that summit oe jegs sells, they both run down the ps into a dual in dual out muffler. They have pre made kits and are around 225 I think.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya I looked at that kit but the rear pipes will not fit the blazer the gas tank is in the way.
Swims350
Logan WV
none
oh my bad. I hear some having fitment issues on them anyways.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I found some property I think I want so this project might be up for sale. depends how much down I have to come up with.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
cowl hood fenders and the new grill showed up
jlyon1006
