2 vs 3 v- groove power steering pulley
Lithium grease and made it happen with some 5/8" hose. Gonna loose my sh*t over a power steering pump. :Stupid Me:YOU DID WHAT?
Did you sya you used lithium grease to slip a HOSE onto the barb of the return?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
No. Remote Reservoir. 3/4"; 5/8" hose, because new pump feed is 5/8"...
Should I put a little anti-seize on the shaft before I put the pully on, or lithium greese?
DO NOT USE A LUBRICANT ON A PRESSSED SHAFT.
do NOT lubricate an oring with a reservoir onto a pump body with anything but your choice of power steering fluid.
71Muscle
