2.5" or 4" Lift 1986 K10
danzey
Kansas
Danzey
Redfish your post inspired me. I went from a rough riding 4” superlift to your setup. I didn’t want to mess with the front springs so I went with 2.5” rear blocks.
Now I need to get a new steering gear and power steering pump - probably a Borgeson shaft without rag joint….
Shorty81
Baby Boomer
North West ohio
Darren
That looks perfect!! My K20 with 1" lift and 31" tires
Redfish
Prairieville, LA
Andrew
V1500
@danzey your truck looks good. You have a lot of potential there. What are you going to do about a front bumper?
danzey
Kansas
Danzey
I’ve got a brand new premium bumper from LMC. Remaining items I’m working on is all new borgeson steering gear and shaft with new PS pump, bumper, and probably will remove a leaf from front springs to get a bit of rake as well.
Redfish
Prairieville, LA
Andrew
V1500
@danzey here are a couple of pics of my spring removal. I took the bottom, short spring off each side. In the second pic you can see the bolt that holds the springs together that you will need to shorten a bit. If you don't cut the end off the cap that bolts down on top of the springs will not seat against them.
In case you are wondering, yes it does ride a little bit softer with that spring out. It also rolls a little bit more in the curves but this isn't a sports car so I don't let that bother me much. I have zero regrets for doing this little modification.
danzey
Kansas
Danzey
Update:
front springs ended up settling a bit without removing a leaf - and now I would say this is dead level - 40" to fender well front and back.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Here is my 79 K 10 with 2" front 3" rear lift and 33" tires.
older video with the original 400 engine
Auburn, Washington
She’s a beaut!
Camar068
10 yrs Air Force
Update:
I see a bit of rake. If thats a concern, an easy fix might be the Monroe coil overs on the front. I've got them on a stock k10 (front/rear) and it leveled it out. Worth a shot for under $100 for the front shocks. 'Course you'll have to measure for correct length since you lifted it.
I've got the set front and rear and it's level to my eye with 32" tires
Redfish
Prairieville, LA
Andrew
V1500
It has more rake now. Both @danzey and myself prefer a bit of rake. I actually wish my truck had a bit more rake than it does.
89GMCJimmy
ivan
ORD also has 1" Zero Rate Add A Leaf Axle location can stay in the same spot, or you can move the axle forward or backward 1" or 1-1/2".
These were perfect when my rear axle needec just a bump up
nbrizjr
