Burb209
- Dec 16, 2021
- California
- John
- 4x4 Suburban
- 5.7 L
Yes there are, I just asked this question the other day, the factory bulb is a 906. I saw some that said 921 leds were replacements for quite a few of the 900-910 or whatever it said.Thanks again. Are there LED’s available to replace the incandescent bulbs?
Inside the cubbys. Those are for the retention/tension on the sliding cubby doors.I was using this thread as a tutorial to pull my console, but when I did and flipped it over, this fell out... anyone know where it's supposed to be vs flopping around freely?
Should be 4 black 10mm bolts that hold the plastic shell onto the metal frame, you should see them inside the sunglasses holder areas. Take those bolts off and then while supporting the console slide it forward, it should drop down and be free from the roof, disconnect the wiring harness, a single 3 pin plug. Take it out of the vehicle and start removing screws from the top. I forget how many there are, 10 maybe 12? and tart replacing blubs! If you use LED's test that you got the polarity right before you reinstall the console in the truck!
