VAL
- May 29, 2012
- TUCSON, ARIZONA
- VAL
- K10 SILVERADO
Well, I wrenched on it all day today, here's the bracket that I had to modify a bit. It bolts to the PS pump, alternator and exhaust manifold. I read that you can run it with out this bracket, but I decided to use at least on bolt with a spacer on the manifold anchor. I had to cut one off, I figured better one than none. I also got a reverse fan from a 2000, I had thought about going electric fans, but after seeing how much more air this puppy pulls, there's absolutely no need to go electric. In my opinion.
