1987 Suburban Idle Issues
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
Having been down this rabbit hole before and pretty much followed the pattern you did, I ended up finding the throttle shaft bushings were worn and allowing air to bypass, and it did not show up when chasing Vac leaks, I replaced the TBI unit with one of the modified ones that you see on Ebay worked a treat and even picked up a few HP.
Have since gone to a Holley Sniper set up and have the TBI unit sitting in a box on the shelf.
Smokenbones
Arkansas
Kenneth
Have you tried cracking the gas cap to release the pressure before trying to start it. Not sure if the cap is supposed to be vented or not but have had them to fail.
sam s
