Cdog_96
- Jan 15, 2022
- Aiken
- Clay
- K10
Hey everyone, got a professional built long block SBC 350 TBI and am putting the pieces together to finish it. I noticed a couple of the main caps are using long studs, what is this for ? Also I purchased a 4 quart oil pan which I believe is stock for the 1987, this is a stock build btw. The studs clear but only if they go into the hole provisions in the oil pan, is this correct ? They hit the oil pan otherwise
I know the main caps are in a fixed position so idk if they clear through those wholes it may be fine. I put red grease on the tips of the studs to show where it hits, but this is before they slide in the oil pan holes Any help appreciated, thanks
