- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I would do the timing and IAC steps before replacing the IAC. it sounds like the computer is getting confused about the air thats coming in and jumping around trying to correct (which is what happens when its not properly set)I’m not 100% sure on the startup fuel spray subject. But I just drove the truck home after it sat for about two and a half hour and it ran like junk at idle it was shaking and stalled first time but started right back up but sounded almost canned the way idle was dropping to around 400 and back up. I rolled to a stop sign and the truck dropped to under 100 rpm( tach bottomed out) and service engine soon light came on but then it jumped back up to 650 - 700 and light went out. Could this be the iac? If it’s cold it idles like hell but other than that runs great now. I’m having to get used to shifting again since it doesn’t shoot upto 2kwhen I press clutch
