1987 454 TBI stalls at idle after a short time
beady
Tidewater/Northern Neck VA
Mine
R20
Been a couple weeks, any progress?
Sorry, was too damn cold to do anything for seemingly weeks, then I had the flu this week.
I bought a new Bosch 12014 single wire O2 sensor (didn’t want to mess with adding other variables with 3-wire, and cheap) and installed it today. Computer not seeing the O2 sensor it seems, reading still never changes from .451 v and nothing gets populated on the o2, blm, or int tables.
I cleared all codes and it is not showing any codes now. Should it throw a code not seeing any O2 signal change? I let it warm up to operating temp with the same result.
Guess I’ll look for the ecu pin out and see if I can read changing at the ecu connector pin and/or check continuity from ecu connector pin to the O2 connector.
I’m open to other suggestions on what to check.
Thanks,
gmbellew
Kansas city
glen
suburban 1500
Thanks,
seems I remember somewhere about issues with Bosch O2 sensors not working well.
constant .45v means the ECM and wiring is ok. but for some reason the O2 voltsge isnt changing. I'd try an AC Delco O2 and see if that fixes it.
Bill USN-1
US
Bill
Nope.
Unplug your O2 and the aldl will still show .45mv
Bill USN-1
US
Bill
Thanks,
All the wiring diagrams are in the injection forum on binderplanet.com
Here's the pinout with the key on test you can perform.
Just back pin the connector.
I normally remove the blue comb to make it easier.
So, unplug connector from ECM, find pin D7 and read it from connector to your O2 connector.
Then check the O2 sensor gnd to eng gnd.
Error codes are based on specific criteria.
Normally you won't get an O2 error until you drive it fully warmed and the ECM is waiting for a specific reading.
This can also include VSS input like the EGR test uses.
beady
Mine
R20
I went and drove it while you were posting that to see what happened. I did get a few hundredths change and it populates 3 cells of the O2 table. The truck has what look like aftermarket cast manifolds. The O2 sensor is on the driver side collector, o2 reading only changed when I got on it a few times so I’m guessing it isn’t getting hot enough.
I found the 3-wire sensor and adapter I had (GM 19178959), I’ll try it tomorrow. I have a ‘93 OBS 2500 350 TBI Suburban also (it’s totaled tho), I had bought the sensor from Harris maybe 2 yrs ago but never installed it.
Oh yeah, it is showing O2 error code after driving.
Thanks,
Bill USN-1
US
Bill
Thanks,
If you drove it, you should have logged data and BLM.
beady
Mine
R20
I went ahead and installed the 3-wire O2 but just rigged up the power to it temporarily. There are more O2 sensor readings now, but it doesn't change a lot.
It still populates zero cells in the BLM or INT tables. I don't know why. It does populate the O2 table cells though.
I took a short drive up the country road and back and logged with the 3-wire O2 active, log attached to this post.
  • 20250201_173257_LOG.txt
beady
Mine
R20
Rusty Nail
Rusty
350sbc
Hello again, I have this new to me 1987 454 TBI suburban that I’ve been chasing problems down in. Today’s issue is stalling after a few mins of idling.
The previous problem was power being way down, to the point where it would max out at 47 mph and you could only use literally the first 1/4” of throttle travel before it would rev seemingly ok, but make even less power. This turned out to be a loose/worn distributor/cap. I replaced distributor and more, and it ran pretty well for a week. I put maybe 50 miles on it, but last week I started it and walked away and it stalled a minute or so later. Now seems to be the truck’s MO. What I’ve replaced or checked:
Brand new:
DUI distributor, coil, wires
Delco plugs
MAP sensor
Delco injectors
Delco FPR rebuild kit
Fuel pressure was 13 psig after filter
Timing set at 4-5 dtbc with ignition wire disconnected
Here’s a video of it stalling I took earlier today:
The last thing I did was the distributor, coil, plugs, wires all at once. The idle sounds great, nice and smooth, no bounce or bauble. I’d love any thoughts or ideas on what to do/check next.
Thanks,
This is High Quality posting Mike..lemme have a look.
Rusty Nail
Rusty
350sbc
Woah dude. Dang!
That's some serious posting y'all are doing.
Hay look. I saw vbb!
I seen ol whats his name in there watchin too.rick.
I was eating pizza and it was yummy! :Boo:
Well.
Lemme think about it.
See all you partners later!
beady
Mine
R20
Woah dude. Dang!
Well.
Thanks, lol. I figured if I gave good background what I’ve tried it would get better results.
The problem has sort of morphed along the way, but have made lots of progress.
Rusty Nail
Rusty
350sbc
Well. So far i've been wondering why the speedometer is inop and I keep wondering about the exhaust manifolds you referenced more than once.
I also wondered if the rear air works and what color the truck is.
Cuz see there's no pix.
It's hard to tell what's goin on...buncha wondering!
This has been my favorite song before;
:headbang:
Back to the manifolds though.
Maybe i'm wrong? but in some vehicles I know i've seen a fairly considerable ground strap attached to a manifold bolt through an "o ring". Yes.
AND THEN I questioned how the starter wires got hacked. Transmission RnR
OR
Has the motor been out too? The underhood presents very well but i'm not convinced. More information and some Dying Fetus IS necessary! :)
Tearing through the Womb - like your BigBlock!
Remember about the other ground strap that connects through the bellhousing?
AND what does the oil change sticker say FFS? F v ck Around and Fix It (FAFI) with some 10-30 and a Wix! wouldnt be the first time :(
How am I supposed to fix it when I don't even know what color it is?
MIKE
Bill USN-1
US
Bill
You're still showing an O2 error and it is still not reading correctly. If it does not increase to 600mv it will not go into closed loop with BLM enabled on the flag page.
Did you meter the wiring?
TPS looked better at first but then went all over the place.
So you either have a TPS issue or you have bad grounds.
It will not go into idle mode if the TPS is out of spec.
I strongly recommend you start reading pins and wiring and not swapping parts.
Use the sheet i attached and print it out.
Do the key on test and then the engine running test.
Write the readings you get on the sheet so it can be reviewed.
If there's been a lot of hack maintenance done on this truck, then all of the gnds and gnd straps may not have been reattached on the back of the engine.
The harness can have 1, 2 or 3 gnd ring terminals that contain the system and sensor gnds as shown on the pinout.
I have also seen them attached with the wrong bolt and the bolt is tight but the ring terminal is still floating loose.
  • 20250201_173257_LOG.zip
Rusty Nail
Rusty
350sbc
I like barking at this tree.
Does a big block have an oil pressure thingy near the distributor AND near the oil filter warning light like a small block?
A ground there.
The ground at the thermostat housing?
Bad connection/ground at these places could VERY EASILY cause that symptom.
Needs moar pix.
I'm putting a bet on bad engine ground.
Hope this helps!
Warms up/changes shape/repeat.
No morphing. :nono:
rhaydok
