beady
- Jul 20, 2024
- Tidewater/Northern Neck VA
- Mine
- R20
TH400, sorry. Odo reads 80K.Probably a TH400 but OP didn’t say.
@beady, so fresh rebuild didn’t slip a couple weeks ago and now does?
Did the seller give you the rebuild receipt? Since it was just done?
Likely there’s warranty, although maybe you can get the seller to take it in? Little gippo shops a lot of times only honor warranty to the “current owner.” Great way to reduce warranty claims….
I’d ask the shop anonymously and go from there.
The guy I bought it from (guy has a shop, all the cool toys, etc., so works on stuff) said he had bought it for his son and went to preemptively service the trans (since he didn’t know what shape the truck was in, even tho it’s super clean) and dropped the pan and saw black residue. So he dropped the trans and took it to his friend with a trans shop (country area, so I think is legit) who rebuilt it. Then the guy put it back in. His son ended up with a job who gave him a 4x4 work truck, and they had other toys, so decided to sell the Suburban. As I said above, trans is pristine externally, as is fluid, and I believe the guy. I live 5 hrs from where I bought it tho, so it’s not a small deal to get down there and back, let alone if I had to leave it there and make the round trip twice. And I seriously doubt it’s a chain place, lol.
I’m just not an auto box guy, so haven’t had to mess with them much before to know symptoms. I’m pretty sure if I take it to a shop they will just say “it needs to be rebuilt” to make money and not say “sounds like low line pressure from a poorly installed seal on the A solenoid in the valve body” (I made that with my limited knowledge, lol).
No one has touched a vehicle of mine since 1999 except for mounting tires and alignment. Clutches, suspension, engine pulls, head gaskets, everything by me. I refuse to break that streak for a fully mechanical auto trans that I suspect has a rebuild error (leaking by seal, clutch packs too loose, etc.) which I should be able to diagnose and repair, lol. I’m even willing to pull it apart and rebuild it myself if I can be fairly confident of the issue.
My long term plan for the truck was to manual 5-spd swap it anyway, so if I can’t resolve this issue for under $500 in parts I might as well suck it up and go for the manual swap now. It’s our backup tow vehicle for trailering, so I’d prefer to get it working as-is now and figure the swap out before I dive into it.
Thanks,
