1984 k20 question
1984K20CD
NW Iowa
Derek
I just bought a 1984 K20 it has a 350 with automatic was a manual trans a one point. I’ve been doing so research but can’t find what I’m looking for. Trying to figure out what transfer case I have it appears to be cast iron. The lever back toward seat is 4hi then neutral then 4lo. It has lock hubs up front. From what I read it a np203 if that’s true shouldn’t it have hi and lo lock then? 5 positions instead of 3? Any info would be great.
Thanks, Derek
nvrenuf
Mobile, Al.
Post a pic.
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Most t/c units have a round, red tag that tells model. Might be buried under crud.
idahovette
Weiser Idaho
Perry
K20-K10
Can't remember ever seeing a tag on a cast iron tc. Should be either a 203 or a 205, and I think the 203's had an aluminum tailshaft housing?
Sounds more like an NP205 IMO. No telling though, someone could have swapped the T case handle knob. If it has manual hubs then they'd have to be locked up for the truck to move if it were an NP203 unless it had a Mile Marker part time conversion kit in it.
1984K20CD
NW Iowa
Derek
I was messing around with pickup yesterday if hubs are in free truck won’t move.
1984K20CD
NW Iowa
Derek
This is on drivers side
1984K20CD
NW Iowa
Derek
This picture is on drivers side. It has aluminum tail shaft.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
NP203 has a differential in it that would do just that. There should be a lever position that locks the center diff that would allow it to move that way.
Not saying that's how you should operate it, but it would confirm what I suspect.
thom9719
