1984 K10 Steering Column question.
Shawn Wheeler
Tilt steering column. The tilt works fine. However, I recently noticed the wheel will move right to left and up and down if I try to make that happen.
This could have recently started, or I recently noticed now that I am trying to fix all the little things after 34 years of ownership.
Also, the ignition switch is getting tough to remove the key.
Could these be interrelated?
I watched the video or changing the ignition switch, looks like quite a bit of stuff for me to mess up.
Does the column need to be rebuilt?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Not sure if the difficult key removal is related to the wobbly column.
These four torx headed bolts loosen up over time causing the column to wobble. It’s quit the job breaking the column down this far but, if you remove the wheel, lock plate, and turn signal switch you can get to two of them IIRC. It couldn’t hurt to refurbish the upper portion of the column but do some research and be prepared for a change.
You may try lubricating the lock cylinder with graphite or some other dry lube to get you by.
Dleslie212
Phoenix
Dustin
5.7L 350
Cal is right, it's those 4 bolts loosening up. I completely rebuilt my column about a year ago, including all new bearings and any part that was still available for purchase. It started by wanting to tighten up the play in the wheel. If you get far enough into it to tighten those bolts up, make sure you use some Loc Tite to keep them from ever loosening again
sparky77
