1983 K10 saddle tank replacement with in frame tank
csmill83
Ridgefield WA
Carl
I currently have bad saddle tanks .looking to replace with a single between the rails tank. I can find tank for 68-72 but none for the squarebody. Am I missing something? my stepside is a short bed k10
legopnuematic
Licensed Junk Dealer
MO
Spencer
Lots of good information Here on putting a blazer tank in a pickup.
Strick
Dunn, NC
Harold
C20 Crew
Welcome to the site and as @legopnuematic states, there's plenty of info for doing a Sub/K5 tank on these trucks. I didn't buy a kit but used a K5 tank and straps along with building my on mount when I built my '55 truck a few years back. It's not that difficult.
HS
GH0ST
Daniel
6.0 LS
How do you guys do the fuel filler on a step side with a blazer tank? Currently doing my first ls swap (17yo) and almost done with engine bay wiring. Once I’m done with that I’ll move on to the fuel side of things but want to have an idea before I start moving stuff around. Thanks
kkgp81
Kelley
There are a few options. Blazer tank, suburban tank, or a Boyds unit which is a very nice unit and doesn't need a bunch of messing about to install where the first two options will need some crossmembers pulled/moved.
kkgp81
Kelley
My suggestion would be through the bed floor on a stepside. You may be able to run a hose all the way up to the filler though. On my project I brought in a LS Fab tail light filler setup but I am using a fleetside bed.
If you filled in the marker lights, you might could swap the fenders from side to side to put the filler in the rear lol
Boy, they sure are proud of that setup... $850 is wild
kkgp81
Kelley
Quality cost money…. The blazer tank I’m using from TanksInc has a price tag around the 7’s. Luckily I got it for a smoking deal in the summit outlet. I think I’m in it 2 or less and it came with the fuel pump.
If I was in the market at this moment I would go with the Boyd’s. If I had to out a price on my time it would have been cheaper.
Post #7 here has a top view of the blazer tank install from Tanks Inc.
My setup looks a lot like yours, except I bought the 31 Gallon Blazer tank with sending unit, crossmember, straps, filler neck, and all stock sheetmetal components locally for $40. If anything fails or needs replacement.. I can just go into any parts store anywhere and buy an OEM 87-91 Blazer part and move on.
The boyds would be a good option if you are building a show car or something. I couldn't do the 19 gallon tank... 31 already feels like a stretch.
There's a thread on here somewhere from a few years ago that a member made one of those behind the light setups pretty easily but I can't seem to find it. I know there are several, but the one I'm thinking of was a red truck and it was burried about halfway through his build thread.
kkgp81
Kelley
I get it, we all have different ways of going about it and the results are generally the same. The current problem with your tank is it’s a fixed turned neck tank forcing you to go to the passenger side with a possible ability to flip it around and go drivers. There is a thread/ vid here somewhere where they ran the hose to the normal spot with a long hose. The only problem I saw with it was it was visible in the wheel well but it was a good solution. There are also a few vids moving the fuel door on the bedside. If you have the tools and skills this is a good option.
Doug Hampton
