1968 327 in a 75 stepside
qwas37
Austin, Texas
Everett Byrom
c20 Stepside long bed
Great read. Could OP need to double check push rod length? If cam timing is off, would more than one piston show valve kiss or rods bent?
Perhaps I should check the pushrod length while I’m here. All of the Pistons on the passenger side have valve kiss but no push rods are bent. I checked them by rolling them on a flat steel surface.
qwas37
Austin, Texas
Everett Byrom
You'll probably find a lot more 193s than 083s or 601s but despite all the bad mouthing people give 193s they are a great work truck dd head.better mpg and lowend torque. That's what they were designed for, the swirl atomizes the fuel so it burns better,so you use less ignition timing to light it off. The reduced timing means the piston isn't fighting ignition as long on the upstroke. It's minimum best timing. MBT. Everyone attributes the power and mpg of the the tbi trucks to the tbi,nope it's the tbi heads.
This is good to know as it will help broaden my search.
Stopman33
