10 bolt Front Problem 1990 Sub V2500
Bright Idea
Scappoos, OR
V 2500 Suburbans
I have a 1990 V2500 Suburban. It has the 10 bolt GM front axle and I am led to believe that it would have the 30 spline inner shaft ? Is this correct ? It is 4:10 gear Ratio. I have a random intermittent popping sound/clunk when running in 4wd. I believe I have narrowed it down to the right ( passenger side ) It only does this in 4wd with both manual hubs locked. with the right hub unlocked and the transfer case in gear either 4hi or 4lo the noise /popping does not happen. I have had the manual hub apart and it is fine and works as it should. I suspect either something with the axle shaft or internal in the differential. This clunk/bang occurs very randomly and does not involve turning. Any Ideas before I tear into it ?
dvdswan
Port Orchard, WA
Dave
Steering knuckle u-joint?
Bright Idea
Scappoos, OR
V 2500 Suburbans
I am not real familiar with 2 piece axle u joint failure.With the limited access it is hard to tell if there is any slop in the joint. Possibly this is the beginning of the u joint failing ? Turning does not seem to make any difference ?
TubeTruck
East TN
Denis
Suburban K10
LQ9
Go from behind the front axle and grab the drive shaft an twist it back and forth. See if there is any play in the u-joint. You can also use a big screwdriver or prybar to see if there is any play.
You should see this
GorillaHumper
