- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Anyone here have any experience with the 4t40e transmission? @HotRodPC maybe?
I wound up purchasing an '05 Malibu with the 3500 v6 and the 4t40e trans. The car has a little over 200k on it now. 1st and 2nd gear work absolutely perfect in all throttle/load conditions. But 3rd and 4th gear simply do not work. As in, this thing doesn't even try to shift past 2nd gear. Is this likely a solenoid or electrical problem? Or just a toasted trans? I don't own a scanner to check for trans codes, but if I can't turn up any info, I'll just have to call in a favor at the old shop.
