Johnny Atomic
- Oct 18, 2019
- Little Rock AR
- Johnny
- Sierra Classic 1500
I'm having an intermittent problem with my truck. When the engine is cold it starts great. But if i try to re-start it after driving 20mins or more, the starter drags then will generally start. One mechanic said it was the battery ground cable. so I replaced the ground cable with a 2 gauge instead of 4 gauge. Problem still exists. Next place I took it tightened and checked connections on starter, did a load test on the starter and said it was fine, and tested the battery and said it was a little weak (4 years old) and replaced the battery. It is still having this problem, one guy there said it was the timing was off, but it is set exactly to specs on the radiator support.
