04 Suburban oil pan, whew
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Holy oil sludge batman! Might not hurt to replace the oil pressure sensor, don't know if your era has the screens on them or not. I would imagine if it did it would be clogged up from that sludge!
Yeah, I thought of that too. I might.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
This is a good read here, but like I said, this is for 07-14. Not sure about your gen. @Old77 ?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
That is a good read. Similar solution, seafoam for clean out which you may have seen results, and been running the oil change with the Rislone. Quiet now.
I use high milage stp synthetic and get their extended life filters (10,000) and change every 5-6k.
Been doing awhile, but I know the PO and doubt he used anything good other than cheap.
I didn't realize the oil pressure screen was that big. Definitely looks like worth the curiosity to change it and sensor.
Glad I didn't get into lifters. I can't be rebuilding two engines, lol.
Is definitely worth the effort. May not solve all the issues but won't hurt, either.
Hunter79764
Grand Prairie, TX
Suburban V20
Do the screen if you get bored, but I'll second that 20 psi hot idle ain't bad. I had an '01 Suburban with 3xxk miles that did similar. I think I replaced the oring and de-sludged the pan around 250k, and a lifter would tick after about 3000 miles on an oil change. I just used it as a reminder when to change the oil and kept trucking. Eventually I thought I'd get ahead of it and replace the engine with a lower mile pull-out when it had 320 or something, but it was a mistake, the new one had a cracked head or something intermittent that head gasket sealer in a bottle took care of. Ended up selling it for other reasons, but I think that the original engine would have kept going just fine till 400+. don't remember the hot idle psi, but I doubt it was much higher than 20. All that you need is enough to push it everywhere it needs to go in the engine, and rise with RPM, and it looks like you have that. Run it...
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So, interesting update. Had a couple start-up growls. She uses the usual quart between changes. At about 5k+, since seafoam, and using 1/4 quart of rislone (added another 1/4 when I added oil) I did oil change.
Oil filter was pretty heavy, looked like quite a bit of gunk.
Start-up and oil pressure looks close to or normal! I haven't replaced oil pressure sensor and screen yet sitting there.
Runs 40 psi, 35ish when hot, and 45-50 @ 2000rpm and above.
unimogguy
