nvrenuf
- Jul 30, 2010
- Mobile, Al.
- John
- K5
Something to consider is that the D60 most likely has 1.31" dia axle shafts so they don't offer much of a strength upgrade over a 1/2 ton axle other than the better weight bearing design of a full floater vs semi floater axle. The ring & pinion is bigger than 1/2 ton and the Power Lock is excellent but if I had both to choose from I'd go with the 14 bolt without hesitation.
Edit: the 14 bolt is going to have roughly a 1.5" dia
